| Latest | 0 Rplys |
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450. |
04-28-2004, 05:06 PM | #1 | |
transmission not working right
i have an 88 e350 c-6 i just put a junkyard tranny in it. it will not go over 60 mph. does any one have any ideas.
05-09-2004, 09:41 AM | #2 | |
Banned
Re: transmission not working right
Does this happen when driving on a flat surface highway or on a little steep highway?
05-09-2004, 11:17 PM | #3 | |
All the time. It will not go over about 60 mph. The engine is screaming.
I have changed torque converter with same results. |
05-10-2004, 12:24 PM | #4 | |
The vacuum line to the moduator is either plugged, not connected, or there is a cap on the modulator nipple. The modulator *thinks* you are wide open all the time (no vac signal) therefore it will NOT upshift to 3rd.
05-10-2004, 10:29 PM | #5 | |
It is shifting into all the gears, just as it should.
05-11-2004, 09:53 AM | #6 | |
You said: "It will not go over about 60 mph. The engine is screaming."
That would indicate it's not getting into 3rd. Try a "D" to "2" downshift when it's doing this. If the RPMs do not increase you were NOT in 3rd, but in second. |
05-11-2004, 08:33 PM | #7 | |
Thank you for the info. I will check the vac. line in the a.m. I did try the downshift and it did exactly what you said. Thank you very much for taking the time to respond.
