Old 02-21-2004, 02:58 AM   #1
chinesechickens
chinesechickens's Avatar
tutorial-titanium muffler tips
I have noticed that a lot of you have been trying to find a way to make realistic titanium tips, so I thought i`d share my way with you.
(sorry, not very good pics but you should get the idea)
Materials:
1 chrome telescopic aerial (from a radio)
1 mini blowtorch
1 pair of pliers
some cold water
first cut up the aerial into its sections.
use the size section most suitable for your exhaust size( I have used the thickest size for photos.)
then light up your blowtorch and while holding the tube with pliers(gently do not squash)heat the tip of the tube by placing the flame directly onto the metal.
once the metal is red hot, dip it in the cold water to cool.
you will notice the tip is brown in colour,but look further down and you will see the heat staining.now trim off the brown part and cut your exhaust tip to size with the colouring right on the end.
this is what you should have after heating:
hope you like my tutorial
chris
Estella warren is hot!!
Power is nothing without control
I thought i saw a v-spec II, i did i did. i did see a v-spec II!
chinesechickens is offline   Reply With Quote
Old 02-21-2004, 03:01 AM   #2
ADVANFAN
Re: tutorial-titanium muffler tips
good tutorial now i gotta go get me some aluminum tubing
ADVANFAN is offline   Reply With Quote
Old 02-21-2004, 05:04 AM   #3
flyonthewall
Car Mod guy
flyonthewall's Avatar
Not thought of that, definately worth a try!
flyonthewall is offline   Reply With Quote
Old 02-21-2004, 07:23 AM   #4
chinesechickens
I forgot something.before you heat the tubing be sure to wipe it with a solvent such as alcohol and dont touch it again with your hands until you have heated it.if you dont do this you will get fingerprints burnt into the metal and/or an uneven finish.
by the way it is not alum tube it is chromed brass, I dont think alum will give the same effect.
chris
Old 02-21-2004, 10:47 AM   #5
slk320
AF Premium User
Send a message via AIM to slk320
good tutorial. you are tight, aluminum tubing will NOT give the same effect.. believe me I tried
In Progress:
FXX - test mule in CF
49' Mercury
slk320 is offline   Reply With Quote
Old 02-21-2004, 11:58 AM   #6
ShOrtyOC714
=p
ShOrtyOC714's Avatar
Send a message via AIM to ShOrtyOC714
Nice tutorial but just as SLK320 said, not all pipes work. If you want the best results try to find some real titanium piping.
ShOrtyOC714 is offline   Reply With Quote
Old 02-21-2004, 02:12 PM   #7
chinesechickens
i actually found some titan tubing...way too expensive!
i found the chrome aerial works second best.
you can find them quite cheap at radio spares shops.
i`m working on some other tutorials too.
chris
Old 07-07-2005, 06:19 AM   #8
marcopreto
Hi to all:
I've been trying similar efects.
I use mainly plastic for my models, so I resort to painting technics to achive this!
What I do is: -paint the exaust in the metalic collor of my choice
- use citadel miniature inks (blue and flesh) with my airbrush
One must look at pictures of the real thing and see how the color changes!
This is an example!
I hope that you like it and try it!
Cheers
Marco Preto
marcopreto is offline   Reply With Quote
Old 07-07-2005, 08:57 AM   #9
mike@af
Captain Over Engineer
mike@af's Avatar
Stainless does the same thing.
-Mike
mike.lawrence@automotiveforums.com | AutomotiveForums.com | Flickr Gallery
mike@af is offline   Reply With Quote
Old 07-07-2005, 11:50 AM   #10
spidereddie
spidereddie's Avatar
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
guys I think (and from the looks of the pic), he's talking about an 'antenna' from a radio. That, to me anyway, seams like a much cheaper and more readily available medium to use as opposed to titanium tubes.
Ed-
spidereddie is offline   Reply With Quote
