Go Back   Automotive Forums .com Car Chat > Rover > General Discussion
Old 12-06-2003, 10:48 AM   #1
cossa
214SI Cutting out!?!?!?!
My first post on here lads so here goes....
I have a 1990 Rover 214Si 16 valve... starts and runs beautifully first time. It happened once where I was driving along and suddenly my car engine just stopped, the revs and the speedo hit 0. The car would not start for a few minutes but then started and done the same again a little further down the road. Now the space in the time of this happening has shortened and has become more and more regular. Even when it is idle it will still cut out. I have no idea of what the problem could be and would really appreciate some help if it is available.
thanks.
cossa is offline   Reply With Quote
Old 12-07-2003, 02:13 PM   #2
mechy1barry
Re: 214SI Cutting out!?!?!?!
check the main engine relay(when it stops give it a tap)under centre console i think colour brown.
mechy1barry is offline   Reply With Quote
Old 07-03-2005, 08:33 AM   #3
Bootneck
Had the same problem, car started great then after a while is you stalled it wouldn't start for ages.
Bootneck
Try fitting a new rotor arm in the distributer.
thanks.
Bootneck is offline   Reply With Quote
