Go Back   Automotive Forums .com Car Chat > Pontiac > Montana/Montana SV6
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 12-03-2003, 09:24 PM   #1
Flatrater
Main GM Guy
Flatrater's Avatar
Keyless remote programming 1998-2004
Perform the following steps in order to program the transmitter:
1. Remove the ignition key from the ignition lock cylinder.
2. Remove the BCM PRGRM fuse from the fuse panel.
3. Close all of the doors.
4. Close the liftgate.
5. Turn the ignition lock cylinder to ACC.
6. Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
7. Open and close any vehicle door. A chime will be heard when the system enters the BCM programming/diagnostic mode.
Important
After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
8. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
9. Repeat the previous step on each additional transmitter to be programmed.
10. Remove the ignition key from the ignition lock cylinder.
11. Install the BCM PRGRM fuse back into the fuse panel.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Flatrater is offline
2007 Honda Odyssey Keyless Remote Programming 2009mustang Odyssey 3 12-15-2010 11:29 PM
2007 Honda Odyssey Keyless Remote Programming 2009mustang Odyssey 1 08-25-2010 05:06 PM
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 08:13 AM
How to put BCM into program mode? (Where is BCM/MALL fuse?) copchick527 Grand AM 5 03-02-2009 03:30 PM
chime indicating keyless remote error - 2003 Pontiac Grand Am Jcolli06 Grand AM 1 02-18-2009 06:37 PM
Closed Thread
