Go Back   Automotive Forums .com Car Chat > Ford > General Discussion
Old 08-23-2003, 01:43 PM   #1
OTOOL
Question 1998 Winstar Vibration
I Have A Front End Vibration Starting At 50 Mph And At 60 Mph Is At Its Worst.have Had Tires Changed Out Twice With The Same Tire.michelin Symmetry P205/70/15.took To Another Balance And Did Improve.took To Several Garages And Said To Just Live With It.new Monroe Sensatrac Struts And Rear Shocks.new Ford Factory Rotors,bearings Said To Be Fine By Different Machanics,new Tie Rods.the Front End Seems To Hop On You At Highway Speeds.does It In Neutral Also At Same Speed.thinging About Getting Rid Of The Brand Of Tire.bought The Van Used.had Problem Since.also Front End Alighned Twice.the Tech Said The Camber Was Out Very Slight On Pass Side,not Enough To Cause Any Problems.any Help Would Be Thankfull For.
OTOOL is offline   Reply With Quote
Old 08-23-2003, 03:21 PM   #2
galaxie500fb
It may sound stupid but did you rotate the front to rear. You might just have a bent wheel.
galaxie500fb is offline   Reply With Quote
Old 08-24-2003, 11:06 AM   #3
OTOOL
Re: 1998 Winstar Vibration
YES.AM WONDERING IF THE TIRES ARE NOT MATCHED ON THE RIM NOW.NO DOT OR MARKING ON TIRES TO TELL.
Winstar will not start sometimes bwagner61 Windstar 5 02-21-2010 01:04 PM
1998 Accord - Vibration problems compuser1973 Accord/TSX/Accord Hybrid 3 07-25-2005 02:28 PM
1998 Winstar 3.8L starter just makes a click sound!!! HELP! Ronniezap Windstar 2 06-21-2004 05:32 PM
