| Latest | 0 Rplys |
'88 - '91 Civic | CRX | Wagon | Shuttlee Partnership with: LadyNRedSi.com |
#1 | |
Rear Door Speakers
Is this possible? To put speakers in the rear doors of my 4dr? Or would it be very complicated? Thanks
Name is Adam |
#2 | |
Yea man, its possible. I think it would be really easy actually. I dont know why i didnt think of that. Prolly cuz' there's already speakers behind your head back there.. but the more speakers the better, ya know ?! But here's what i got.
Theres already a hole in the rear door that easily can fit a speaker in there. Actually the hole is TOO big, so just get the same size hole from the front door that your speakers will mount in ( or the size you want to use ) and stick that where the Bigger hole is in the rear door. Then the problem with getting the wire back to the door.. In the front door, you see the rubber plugs that keep dirt/water.. any kinda mess out of it.. so you'll need to run the wires under the plastic door thing on the floor, then up that door devider thing, drill a hole in that that goes into the side of your rear door. In that hole that's drilled now, you need a rubber plug like the one from the front door. ( just go get more front door rubber plugs from the Junk Yard ) put them in.. then you can run the wires down to where the speakers will be. Then just connect speakers.. and screw em' into the mount you made ! Relatively easy. - I was thinking about some custom fiberglass boxes w/plexi glass windows for some speakers ( not subs ) in my trunk w/red lights in it for more SHOW look. ( yes i know this wont boost my hp ![]() ![]()
Civic - Trashed it Integra - Hit and run totaled my ride after a couple 360*'s.. hittin guard rail at 80mph, literally FLIPPING over guard rail, barrel roll 2 more times, crashed front into a tree.. New Plans : Teggy / or / Tiburon |
#3 | |
that would be a pretty cool idea...but just one question...would you have to run new wire all the way from the head unit, or just split the wires used for the front speakers? if so, wouldn't you lose alot of power to the front speakers?
![]() __________________________________ 1997 Honda Civic CX Hatch |
#4 | ||
#5 | |
would i have to make up any brackets or anything for the speakers? becuase when i was at the junk yard, there was a 4dr with the one door panel off, and it was just like a big square opening. and plus it would be nice to use the same type of speaker covers from the front on the back. so ill have to look into that, and yea i can just run speaker wire from the head unit to the speakers, no biggie.
Name is Adam |
#6 | |
-Yea, you'd have to make some kinda bracket or something to hold the speaker in the back door.
