Go Back   Automotive Forums .com Car Chat > Hyundai > Elantra | Avante
Old 05-21-2022, 09:48 AM   #1
Rottweiler28
Rottweiler28's Avatar
Irratic idle, car stalls, cel flickers, engine rough
Hello. I own a 2004 Hyundai Elantra gls.
It has approx 160k kms on it. I took it to a mechanic to replace my high pressure power steering hose.
Also replaced spark plugs, air filter and cleaned maf sensor. Car ran great for few hours then out of nowhere my idle started to bounce from 800 to 2k rpms while wither driving or parked. When it jumped it makes an audible click sound and CEL light flickers each time it does but usually never leaves and codes. Main code i get is bank 1 02 sensor hot.
Ill try to upload some code pictures i took and a short video of this happening.
What i have done so far.
Replaced spark plugs
Checked spark plug gap
Air filter
High pressure power steering hose
Changed MAF sensor
Changed IAC sensor
Cleaned throttle body
New clamps on throttle body
Changed fuel pump relay
Changed main relay
Changed crank sensor
Changed engine coolant temperature sensor
Tested cam sensor
Tested crank sensor wiring
Tested battery
Tested alternator
Smoke test vacuum leak passed cold
Changed coil packs
Cleaned all grounds and reconnected
Added additional body ground
Rottweiler28 is offline   Reply With Quote
Old 05-21-2022, 10:17 AM   #2
Rottweiler28
Re: Irratic idle, car stalls, cel flickers, engine rough
Here's a link to a short Video i made to show what im seeing in my car so its more understandable by others and hopefully helps me solve this issue.
https://youtube.com/shorts/c4xoiOKxZ_g?feature=share
Old 05-24-2022, 12:06 PM   #3
Rottweiler28
Not sure what happened with this forum over the last 10 years, but WOW, its like nobody is here anymore.
Tags
idle , irratic , rough , stalling
