Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '06+ Civic
Old 05-05-2022, 05:26 PM   #1
problemsolver08
Extended Turnover
2017 Honda Civic LX
In the morning, when I go out to start the car, the turnover is extended a few seconds longer than normal. Only does it once a day (in the morning). The battery was recently replaced (tests normal). Alternator and starter test normal too. Started a few weeks ago. No lights on the dashboard. The car drives smoothly otherwise. Any advice? Could temperature changes be causing this?
Thanks
problemsolver08 is offline   Reply With Quote
Old 05-07-2022, 12:11 AM   #2
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
Re: Extended Turnover
Miles on vehicle and temps might help. Also, is it pushbutton start or have a key?
If key- it could be a fuel issue -- try clicking to "On" position and let the fuel pump run a second or two.
Report back and let us know....
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
fredjacksonsan is offline   Reply With Quote
Old 05-08-2022, 05:47 PM   #3
problemsolver08
The car has 65k miles and it has key-start. Followed what you recommended; revved normal. No lights has turned on either. Temperatures have been constant but the issue is still going on. Could it be carbon build-up?
Old 05-08-2022, 05:49 PM   #4
problemsolver08
Also, allowed it to pump for a second but it still does it. Still only one time a day (in the morning)
Old 05-08-2022, 06:27 PM   #5
fredjacksonsan
If that is the only issue...and the vehicle is good to go....I'd just drive it. Probably something in the fuel system is draining overnight.
