Go Back   Automotive Forums .com Car Chat > Geo > Metro
Old 12-30-2021, 08:52 PM   #1
MotoExpedition
Gearbox rebuild issue
Hi there
I'm in the middle of a gearbox rebuild (Black cover).
The front input shaft bearing failed and took out the seal.
The instructions i've read and the videos i've seen show the two shafts being pulled out without resistance.
I had to use a hammer to tap my input shaft out. It was not coming out by hand and took quite a few taps with the hammer.
My issue here is the new bearing was tight in the bore as well. Which means I'm going to have to tap the input shaft back in but this means tapping on the inner race whilst the resistance is on the outer race...bad for the new bearing.
Anyone experience this or better yet, have a solution?
MotoExpedition is offline   Reply With Quote
Old 12-31-2021, 10:28 AM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Re: Gearbox rebuild issue
Press/tap on the outer race to seat the input shaft bearing instead of pressing the shaft.
Blue Bowtie is offline   Reply With Quote
Tags
gearbox , transmission
