Go Back   Automotive Forums .com Car Chat > Ford > F Series
Old 12-10-2021, 12:46 PM   #1
kremer1964
kremer1964's Avatar
Cluster power loss
I have a 2004 f150 with the 5.4. Having gauge cluster issues that come and go. While driving my gauges all zero out and my radio and dash lights will go off randomly then go back to normal. Sometimes it will happen only once, other times it will do it constantly. Also when i park and remove my keys from the ignition, my speedo flutters with all power off. Anyone have any recommendations.
Go big, or stay home!!
kremer1964 is offline   Reply With Quote
Old 12-18-2021, 10:08 AM   #2
Rasp
Re: Cluster power loss
Not sure in your exact case but I had a bad ground wire connection that caused the same issues for me once. Try and find your ground wire to frame and see if it is corroded/rusted or just plain off.
Rasp is offline   Reply With Quote
Old 12-19-2021, 12:52 PM   #3
65comet
65comet's Avatar
also common is a leak behind the fusebox lower passenger side kick panel that will cause corrosion behind it.
65comet is offline   Reply With Quote
Old 12-19-2021, 02:07 PM   #4
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
Add to those above, I had similar issues on an older Ford. Weirdly enough there was corrosion on the positive battery cable, under the insulation, all the way to about 7" from the battery. Once replaced - all was normal.
Edit: also check plugs/connections behind the instruments.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
fredjacksonsan is offline   Reply With Quote
