| Latest | 0 Rplys |
11-12-2019, 07:48 PM | #1 | |
Engine surges when driving
Hello,
I have a 2016 4runner SR5 v6. It has 17k miles on it. Recently I found that when I drive at a constant speed the rpm surges from 1500 up to 3000 for no reason and then goes back to normal after several seconds. I noticed this last saturday, usually when I drive at 40-50 mph. Any opinion on this is appreciated! Thank you! |
11-14-2019, 06:45 PM | #2 | |
AF -Advisor
Re: Engine surges when driving
I'd start by checking to see if any OBD-II error codes have been set.
Even if the CEL light isn't on a code may have been set that may help diagnose your problem.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
01-29-2020, 12:54 AM | #3 | |
Try to clean the MAF sensor also.
02-18-2020, 09:34 PM | #4 | ||
I have the same runner you have 2016 SR5.. I on forums every day TOYOTA 4RUNNERS ,, this can be a improper transmission fluid issue could be a leak causing this. bring to dealership it is under warranty. 1500 RPM @40 MPH is normal ... 3000 RPM drivetrain ... |
