| Latest | 0 Rplys |
#1 | |
steering rack replacement costs=--- ???
98 lumina.
shop says need it replaced. waht,s a rough estimate of the cost, labor,etc. involved. thanks for any help. |
#2 | |
A990 racer
![]() Join Date: Mar 2002
Re: steering rack replacement costs=--- ???
About 3 hrs labor, some fluid, maybe hoses, then a toe in alignment. You can price the rack online. Local labor rates apply.
#3 | ||
I,m thinking the local "pull a part" has several lumina,s. maybe I,ll get a used rack from there. there,s a lot of mechanics pulling parts that may do the work. the slight fender bender was not so slight after all. lol |
#4 | |
local shops are charging about $875.total.
my mobile mechanic said he ain,t sure if a cross member has to be removed. In that case he can,t do it because he would need a "rack" to lift the Lumina. Is there a cross member on the 98 lumina? Thanks for any help. |
#5 | |
A990 racer
No member, just the subframe, this can be done without dropping the subframe, I don't understand the problem here, as the procedure is all over the net, U tube included. I would not risk a used rack!
