Go Back   Automotive Forums .com Car Chat > GMC > Yukon
Old 01-14-2019, 03:39 PM   #1
Throbbin Rods
Yukon throttle response
2004 Yukon Denali, 6.0, automatic, 4x4. Occasionally when I leave from a standing start and press the gas pedal gently There is no throttle response. 99% of the time it's fine, but sometimes nothing happens. Tach doesn't go up so tranny isn't slipping. I haven't done plugs and wires because it's too darned cold in NH. There are no codes stored. Could this be the beginning of a faulty Throttle Position Sensor? Could the throttle body need cleaning?
I will be doing plugs on the next warm day as I know they can be responsible for all manner of issues.
Any input will be very much appreciated.
Thanks,
Bill
Throbbin Rods is offline   Reply With Quote
Old 01-14-2019, 04:55 PM   #2
777stickman
Re: Yukon throttle response
Throttle body cleaning would be the 1st to do. USE Throttle Body Cleaner ONLY!! Very seriously doubt that it's an issue with plugs.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
777stickman is offline   Reply With Quote
Old 01-19-2019, 08:51 AM   #3
Tech II
I agree....this is fly by wire, TAC system......
It is quite possible, the plate is sticking.......
If you clean it, I would also suggest resetting the modules too....with key out of the ignition, you do this by disconnecting the neg bat terminal first, and then the pos......then hold both cables together for a minute......then reconnect the pos, and then the neg bat cables.....
Tech II is offline   Reply With Quote
Old 03-11-2019, 03:46 PM   #4
Throbbin Rods
Thanks to both of you for your responses. Still waiting for it to be warm enough for my Raynaud's hands to be abke to clean it.
Thank you!!
Bill
