Go Back   Automotive Forums .com Car Chat > Honda > RSX
Old 04-11-2018, 09:26 PM   #1
RSX0Sal
Exclamation 05 RSX factory alarm
Im having an issue with my factory alarm not going off when i mess with the car. I can hear the car lock itself the red light comes on the horn goes off when i lock it and everything but it just wont ring when its messed woth. Is there somewhere in the car that i can afjust the sensitivity?
RSX0Sal is offline   Reply With Quote
Old 04-11-2018, 09:32 PM   #2
Stealthee
Your worst nightmare
Stealthee's Avatar
Re: 05 RSX factory alarm
It's likely a passive alarm so it doesn't have a sensitivity setting. Just messing with it wont set it off. If you want to test it roll the window down before you get out of the car. Shut the door and lock it like normal. Now reach inside and unlock the door with your hand and open the door. The alarm should go off.
Stealthee is offline   Reply With Quote
Old 04-11-2018, 10:00 PM   #3
RSX0Sal
Sounds good I’m going to try that. It started raining out here so I’ll have rob do it whenever it stops but thanks I appreciate it. Do you know when the mechanism isn’t located though?
