Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 12-31-2017, 04:58 PM   #1
dna9656
Static in radio
I got static in my after market radio. I have grounded the radio's case to no avail so I think it must be on the + line. It comes from he brake light switch, power windows and other on/off switching. Ideas?
dna9656 is offline   Reply With Quote
Old 12-31-2017, 05:38 PM   #2
Stealthee
Your worst nightmare
Stealthee's Avatar
Re: Static in radio
You have any LED lights? LED's put off a frequency that can interfere with radio.
Stealthee is offline   Reply With Quote
Old 12-31-2017, 05:43 PM   #3
dna9656
Re: Static in radio
yeah the PO installed LEDs in the dome positions but while I got a steady hum (and that's prolly the LEDs you mentioned that I had not thought about) This static clicks when you apply and release the brakes or operate the windows.
Old 01-01-2018, 08:34 AM   #4
j cAT
Re: Static in radio
grounding the radio case is not a common task as it is grounded when mounted. is this radio with a proper interface connector ? if not then purchase one and it should work out . the speakers must NOT be using the metal sheet metal of the vehicle. OR touching the sheet metal ...as a return to amp.
j cAT is offline   Reply With Quote
Old 01-01-2018, 11:09 AM   #5
dna9656
Re: Static in radio
Thanks for responding!
The PO (Prev. owner) CUT the factory connector OFF and used BUTT connectors to join Pioneer's wires to GM's. The radio is mounted with plastic brackets so the only thing left was the rear bracket/brace and it's screwed into plastic as well so I grounded the chassis of the radio. The Truck came with a premium sound system so the speakers don't have to use chassis ground to work. I think there is something going on with the power supplies to the radio, I think the radio might be connected to a circuit that isn't shielded.
Your thoughts would be appreciated!
Old 01-01-2018, 12:15 PM   #6
j cAT
Re: Static in radio
the radio most likely not the problem but with the hacker connections that is most likely the cause.. check that the radio is connected to the radio fuse . pull fuse .. then radio ground where is that connected possible wrong wire .
using the harness radio adapter for a after market radio this most all times has no issues .. a lot of wires so could be connected wrong ..
one example radio is always on with key in your pocket ....
Old 01-01-2018, 12:25 PM   #7
aleekat
Re: Static in radio
I would remove the power line from the brake switch and connect it to the factory + for the radio.
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
Tags
static/audio
