Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-14-2017, 03:38 PM   #1
sargentsr6
2002 rodeo no gears?
So I changed out the oil on my rodeo, pulled the front end up on ramps to do it. drove it around the block, put in 4 wheel drive for pull just to make it easy to drive on ramps. when I was done it would not go into reverse, so I just gave it a little push to roll it off the ramps, it still wont grab any gears, the Trans fluid was changed about 15k miles ago, and looks to be at good level, I didn't knock anything around when I was under the vehicle... any help?
sargentsr6 is offline   Reply With Quote
Old 11-15-2017, 03:38 PM   #2
Crvett69
Crvett69's Avatar
Re: 2002 rodeo no gears?
Are you sure transfer case is in 2wd high? Might try shifting it into 4wd or 4wd low and see if it will drive
Crvett69 is offline   Reply With Quote
