Go Back   Automotive Forums .com Car Chat > Cars in General
Old 08-27-2017, 03:47 PM   #1
rrb6699
how to diagnose a vehicle has unknown problem?
I inherited 2005 Mercury Mariner with unknown problem. besides that its been sitting about 3 yrs.
where do I start after I check to see if engine is not frozen? it was abandoned in his yard after a problem I don't know about. I assume it wouldn't run.
I'm getting a battery, gonna squirt marvel oil in the plugs. my bet is electrical or brain issue but I have nothing to go on. its high mileage I'm sure so ill guess over 250,000.
any help appreciated.
rr
rrb6699 is offline   Reply With Quote
Old 08-28-2017, 08:51 AM   #2
aleekat
Re: how to diagnose a vehicle has unknown problem?
You need 4 things. Compression, fuel, spark and spark at the right time.
Edit: I wouldn't use the battery the 1st time to try and turn it over. Pull all the plugs, squirt some penetrating oil and let it sit. Then I would turn it over by hand.
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
Old 08-29-2017, 02:35 PM   #3
rrb6699
Originally Posted by aleekat View Post
. I wouldn't use the battery the 1st time to try and turn it over. Pull all the plugs, squirt some penetrating oil and let it sit. Then I would turn it over by hand.
engine turns over by hand ok. gonna try a battery next, but can't use one in my primary vehicle. I'll have to get one.
the reason I asked about the brain or timing was bcause if that is the problem will I be beating my head against the wall? I can check the timing marks at least by removing the timing cover this has a 3.0 V6 in it.
thx,
rr
Old 08-29-2017, 06:33 PM   #4
aleekat
You have already assumed what is wrong. Without proper diagnosis you're just guessing. All good mechanics I have known start with the "what is working" and do a process of elimination to determine what is not. Have you considered the engine is good and the tranny is toast?
Old 08-29-2017, 07:33 PM   #5
rrb6699
understand. I'm just trying to anticipate things that will hinder the normal diagnosis process.
just trying to find out what maybe have checked first if possible. I just want to start the engine. I will worry about tranny after that.
update.
Just today (now) I found out from a relative that the vehicle started running erratically then kept stalling. eventually, they couldn't start it at all.
rr
Old 08-29-2017, 11:07 PM   #6
aleekat
Then I would check for spark 1st, the simplest.
Old 09-02-2017, 06:12 PM   #7
rrb6699
sorry, will update once I get a battery. hopefully, this week.
Old 09-28-2017, 06:37 AM   #8
Bharatarora
Listen to the engine's noise carefully and if you still cannot diagnose the problem then I suggest that you should head to the nearest service station.
Thanks
Bharatarora is offline   Reply With Quote
Old 09-28-2017, 02:26 PM   #9
aleekat
He hasn't got it started yet.
Old 10-01-2017, 12:06 AM   #10
rrb6699
ok, had minor issues like a hurricane (Irma) basically hit me dead on with the eye where I live. I managed without power for 9 days and now have a battery to start diagnosing the Mariner.
I will post what happens when I turn the key, if it turns over at all - ill check for spark.
we can go from there. still doin some clean-up. I'll do the start test in the next few days.
Old 10-02-2017, 09:32 AM   #11
aleekat
Glad to hear you are okay. The car can wait...
