| Latest | 0 Rplys |
02-11-2017, 12:50 PM | #1 | |
Popping noise
2002 Saturn SL
I had my outer tie rods replaced. Took it to a shop to find out what else I needed, I replaced the struts, motor mounts, and control arms/ball joints. Bought new tires and had an alignment done. Before the alignment,after starting to roll in reverse I would hear a pop noise in the front. Everyday it got worse until the alignment which then it stopped. It's been a week since then and now there is a pop noise that seems to be something to do with steering. Doesn't happen in reverse anymore, but mostly if I turn the wheel while going very slow or sometimes if the transfer from driveway to road has a little ditch in it, it will pop. Only if I am turning at the same time though. Any ideas what to check? Last edited by Eggston; 02-12-2017 at 05:18 AM. |
02-12-2017, 08:51 AM | #2 | |
Registered Offender
Re: Popping noise
Were the upper strut mounts/bearings replaced with the struts?
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
02-12-2017, 02:45 PM | #3 | |
Re: Popping noise
Yes I replaced the strut mounts.
