Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-19-2016, 12:31 PM   #1
LindquistJon
Ac
I had driven my Tahoe about thirty miles and the air was working great, got home and parked it and heard a hissing noise coming from under the hood. I determined that it was coming from the passenger side. Today went to drive it and the ac was not blowing cold air, any ideas?
LindquistJon is offline   Reply With Quote
Old 06-19-2016, 02:25 PM   #2
j cAT
Re: Ac
there is a high pressure release valve for dumping pressures if too high could be it got stuck open. check for leaks use the UV dye in the R134 charging cans .
sometimes on shutdown it will hiss. high side pressure goes into the low side to equalize the system.
j cAT is offline   Reply With Quote
Old 06-20-2016, 07:07 PM   #3
LindquistJon
Re: Ac
I found on the backside there is a plug or something that blew out is it replaceable?
Old 06-20-2016, 10:05 PM   #4
j cAT
Re: Ac
that maybe the safety valve . I think it is replaceable .. never had to replace one.
this is on the compressor ?
this it http://www.jegs.com/i/ACDelco/065/15...FdcagQodcBQMCg
Old 06-20-2016, 10:13 PM   #5
LindquistJon
Re: Ac
Not sure if thats it or not havent seen it. I did find a part of an o-ring in the threads
Old 06-23-2016, 07:12 PM   #6
LindquistJon
Re: Ac
Their is an electrical connector on the rear of the compressor any chance that it is leaking from there I found the vehicle harness dangling.
Tags
a/c
