Go Back   Automotive Forums .com Car Chat > GMC > Jimmy
Old 05-24-2016, 03:46 PM   #1
Starr75
Sputtering on accelerate
My 98 jimmy is sputtering on accelerate. I have read that I should try an acdelco cap and wires but I was wondering if that would be it cause it only seams to do it when it is raining or damp in the morning. Any help would be great!!! Thank you
Starr75 is offline   Reply With Quote
Old 05-24-2016, 05:00 PM   #2
harleyguy
Re: Sputtering on accelerate
I would change cap, rotor, and wires. That moisture is causing you to lose spark somewhere.
harleyguy is offline   Reply With Quote
Old 05-25-2016, 09:54 AM   #3
MikeCStig
ACDelco is the gold standard for all things GM.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
MikeCStig is offline   Reply With Quote
