Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-06-2016, 03:00 PM   #1
tacoma_man
1990 5.0 TBI wants to die after engine warms up
After my engine gets warmed up the Rpms bottom out and the engine dies. I've replaced my TPS sensor. I thought it could be that cause I can just put a tiny bit of pressure on my fuel pedal and it will idle just fine. It does have a bit of a miss, and I've noticed that when it rains it has a hard time starting. I have put new wires recently and it's still doing it, could it be that my distributor cap has a crack?
tacoma_man is offline   Reply With Quote
Old 01-06-2016, 07:43 PM   #2
Tech II
Re: 1990 5.0 TBI wants to die after engine warms up
Last complete tuneup? You did wires....how are the plugs? Cap and Rotor? Check coil output with a spark tester?
I would clean the IAC and passageway....also clean the throttle plate and bore.....might even try adjusting the throttle plate a hair open more, while adjusting the TPS sensor(usually is play in the mounting).....i.e. whatever the TPS reading is before adjusting the stop on the throttle plate, after you open the plate a little, adjust the TPS back to the original reading.....
Tech II is offline   Reply With Quote
Old 01-07-2016, 09:15 AM   #3
j cAT
missing hard start when damp out would be bad wires/cap/rotor.
engine dies after warm up the ICM. bad high voltage system arcing causes the ICM to over heat.
j cAT is offline   Reply With Quote
Old 01-11-2016, 06:30 AM   #4
rhandwor
Use some starting fluid and slightly enrich the mixture sometimes the two injectors need cleaned. If you have an adapter Napa sells a can of injector cleaner you can run through after pulling relay for fuel pump.
rhandwor is offline   Reply With Quote
Old 01-12-2016, 07:20 PM   #5
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
It could be many things, but if adding a little throttle will keep it running it might be worthwhile to follow Tech II's advice and clean the TB and IAC.
Blue Bowtie is offline   Reply With Quote
Old 05-07-2016, 04:23 PM   #6
tacoma_man
I fixed the issue. I replaced the cap and rotor button, still had problems, it was the throttle stop plate had a bevel in it from the throttle preset screw. I covered the hole with a thin peice of aluminum and it idles just right.
