Go Back   Automotive Forums .com Car Chat > Buick > Rendezvous
Old 05-04-2015, 09:54 AM   #1
pvisser
Send a message via MSN to pvisser
Starting Issue
Hello
Have a 2003 Buick Rendezvous with 340000 Km on it
The SUV is having a strange starting issue.
Turn the key to start, and one of two things hapen
1, its starts and all is well
2, all we hear is a click under the hood. but keep trying (turn the ignition off and on), and eventually it will start
The issue is getting worse.
I am assuming the starter is dying, but before I replace it, just wanted a pro's point of view
Many Thanks
Paul
pvisser is offline   Reply With Quote
Old 05-04-2015, 11:06 AM   #2
DeltaP
Re: Starting Issue
Check battery cables and starter connections. Check the starter/cranking relay.
DeltaP is offline   Reply With Quote
Old 05-04-2015, 12:06 PM   #3
Crvett69
Crvett69's Avatar
Re: Starting Issue
sounds like your starter/solenoid is worn out and needs replacing. next time it does it see if you can find someone else to turn key so you can pinpoint where the click is coming from
Crvett69 is offline   Reply With Quote
Old 06-30-2015, 11:09 AM   #4
SassyW80
Re: Starting Issue
I have a 2006 rendezvous & the only issue I am having is when I go to fill up my tank; it "NEVER" wants too start. Can someone please help me figure out why this is happening?
SassyW80 is offline   Reply With Quote
Old 06-30-2015, 12:35 PM   #5
Crvett69
Crvett69's Avatar
Re: Starting Issue
when it doesn't want to start is engine turning over when you turn key or just clicks or?
