| Latest | 0 Rplys |
03-29-2015, 11:30 PM | #1 | |
2000 caravan 3.3 plz help
My 2000 dodge caravan with the 3.3 is shuddering while in gear and not moving especially in reverse . As soon as you start going it stops . No slipping whatsoever. The van only has 130'000 miles on it . I have been reading and reading and can't find anyone experiencing this same issue . Does anyone have any ideas ? Of course amco has an idea but it's 2250 "rebuild" with it not slipping like all the others I have faith but no experience. plz help if you can
03-30-2015, 01:01 AM | #2 | |
Re: 2000 caravan 3.3 plz help
My thought would be either engine issues, or transmission issues. Here are some ideas...
Engine: Does it seem to be down on power at all? When was your last oil change? If it's been more than 5000 miles, it may be slowing the moving parts down and the oil needs to be changed. When was your last tune up? If it's been too long the spark might be weak and the fuel isn't being ignited properly. This could be from worn spark plugs, plug wires, or bad coils. Transmission: Have you checked the fluid level? Has the transmission ever been flushed? This is a process that involves more than just draining the fluid and putting new fluid in. It's a job that requires special equipment. Other ideas: What about your fuel pump and filters? Are they ok? If not they will restrict the flow of fuel to the engine. Fuel injectors; Maybe they're gummed up. Try running it on premium fuel and see what happens. Anyway, those are some ideas that would be a damn sight cheaper than a full rebuild and are therefore worth a try. I hope that helps. |
03-30-2015, 12:45 PM | #3 | |
Thank you for your reply between your comments and further reading I am going to try plugs and wires and a fuel system cleaner
