Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 07-13-2014, 07:14 PM   #1
arcturusmine
2005 Caravan power steering hose replacement
I have a 2005 Dodge Caravan that is leaking power steering fluid. Got a new pressure hose for it, but not sure how to replace it. How do you get at the end that connects to the rack? I can see where it connects to the pump. Any thoughts?
Thanks,
Todd
arcturusmine is offline   Reply With Quote
Old 08-01-2014, 03:08 PM   #2
jimslaid
Re: 2005 Caravan power steering hose replacement
You will need to remove the the emissions canister and the reinforcement place to get access to the lines. You could try and get at the lines through the floorboard by the steering column by removing the cover at the bottom of the shaft, but that might not work for you.
jimslaid is offline   Reply With Quote
Tags
hose , power , pressure , replacement , steering
