Go Back   Automotive Forums .com Car Chat > Chevrolet > Chevrolet Classics
Old 02-03-2014, 02:46 PM   #1
spacecrow
Bypass Heater Core, 3.8 hose leaks 72 Chevelle
Hello all. The heater coil leaks so I bypassed it by going with a short 3/8 hose between the water pump and radiator and the water pump end of the hose leaks. Afraid of over tightening the clamp at the water pump end. Does someone sell a coupler to connect a 5/8 and 3/4 hoses or is there a way to stop the leak at the 5/8 end? Thanks for any replys.
spacecrow is offline   Reply With Quote
Old 02-03-2014, 03:40 PM   #2
aleekat
Re: Bypass Heater Core, 3.8 hose leaks 72 Chevelle
You can get a 3/4 to 1/2 copper reducer at any plumping supply, lowes, home depot, etc.
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
Old 02-03-2014, 06:48 PM   #3
rhandwor
http://coldhose.com/ Search heater hose fittings.
rhandwor is offline   Reply With Quote
Old 02-03-2014, 08:13 PM   #4
j cAT
copper water tubing fittings will allow you to connect the 2 different sized hoses. you may find plastic fittings but these may not be able to handle the heat.
j cAT is offline   Reply With Quote
Old 02-03-2014, 11:07 PM   #5
777stickman
I got a 5/8 to 3/4 straight heater hose splice (plastic) from NAPA. Ran it for 6 months without issue. It's out now because I replaced the heater core in the '65 4-4-2.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
777stickman is offline   Reply With Quote
Tags
1972 , chevelle , core , heater
