| Latest | 0 Rplys |
Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
09-18-2013, 04:38 AM | #1 | |
overheating after rebuild
'89 s15 jimmy 143,000 miles. Let it sit in driveway for about 15 minutes running after first crank and it started heating up (top hose was hot as he@*). Turned it off, next day installed thermostat, figured it wasn't opening. Cranked it, let it run in driveway for about 15-20 minutes or so and temp was fine. Decided to go do a test drive. About 1/2 mile down road temp started going up again. Pulled over and turned it off and sat for about 20 - 30 minutes to let it cool off. After that cranked it and temp dropped to normal range and was able to get home. Let it run in driveway for about 15 - 20 minutes when I got home and it was fine. Next day cranked it and let it run for about 15 minutes and temp started going up again, hose hot as heck again. Tried burping system cause figured maybe an air bubble was trapped in water pump. Never got any bubbles coming out of radiator. Cranked it and after 15 minutes or so temp goes up again. I've done a few rebuilds on other engines and never had any problem like this. Any ideas?
09-18-2013, 06:44 PM | #2 | |
A990 racer
Re: overheating after rebuild
What was the temp of the lower hose?
09-18-2013, 08:18 PM | #3 |
09-18-2013, 09:02 PM | #4 | |
Use a garden hose with a little water pressure to force air pockets out while the engine is idle and the HVAC on high heat max.
10-08-2013, 07:01 PM | #5 | |
Didn't help. I replaced water pump, thermostat and radiator (found a tiny oil at top). I let it warm up for 15 minutes and it starts overheating so I shut it off. Let it cool off for about 10-15 minutes, crank it then it stays at a normal temp. I am at a loss.
10-08-2013, 08:50 PM | #6 | |
Is it actually overheating or do you think you have a bad gauge or sending unit?
Post back, that's what makes Forums Work. |
10-09-2013, 03:18 AM | #7 |
10-09-2013, 03:19 AM | #8 |
10-09-2013, 10:44 AM | #9 | |
Are you sure T-sat is installed correctly?
Do you have electric fans? if so, are they coming on?
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip, 1989 Mustang LX 5.0 5sp convertible 1992 Camry LE 2.2 1996 Suzuki RMX250 I'm a victim of circumstance [ |
10-09-2013, 04:54 PM | #10 | |
Yes thermo is installed correctly. And the fan is coming on. Seems like if it was a sensor or something like that then it would always overheat. After I warm it up, turn it off for a bit to cool and then crank it up and run it's fine and at normal temp. The only thing I can think of is an air bubble under the thermo and after a cycle it passes and is fine.
10-14-2013, 04:46 AM | #11 | ||
