Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-12-2013, 01:53 AM   #1
usmcscout123
Send a message via AIM to usmcscout123 Send a message via MSN to usmcscout123 Send a message via Yahoo to usmcscout123
Need Help LED Dome light Issue - Pulsating Etc...
Okay, not very electrical savy.... I bought this LED Dome Light bulb replacement for my 07 dodge ram (yes it's the correct bulb)http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
I pushed the new light into its place and turned it on from the dash switch. It immediately started pulsating and when I turned it back off at the dash, it was still running, but was very dim (weird since it's suppose to be off. So I read up around some car forums (that haven't been helpful) and found that I may need to put a resistor in between the two connection points. So I bought this and did so... http://www.radioshack.com/product/in...lue=RadioShack
I placed the resistor in between the two connection points and placed the new LED light in position. The "Dim light issue" went away when off, but now when I turn it on it pulsates for maybe a whole second before it just turns off completely by itself.
Not sure what do from here. Anyone have any ideas?
usmcscout123 is offline   Reply With Quote
Old 05-12-2013, 08:21 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: Need Help LED Dome light Issue - Pulsating Etc...
I'd look into a replacement.
btw, that amazon link doesn't work for me.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
