Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-02-2013, 03:03 AM   #1
redbaron1
2000 ram 1500 cannot get out park
The selector lever just flops around does not move linkage at end of column. Have not worked on the newer style columns. Last time I worked on one they had the gm style column. So any body out there familiar with this style column ?
I could use some info.
Thank you
redbaron1 is offline   Reply With Quote
Old 05-02-2013, 09:18 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: 2000 ram 1500 cannot get out park
Here's a downloadable 2001 service manual.
The download is kinda slow but worth the wait.
http://dl.dropbox.com/u/42304/2001DodgeRam.pdf
Start at page 1599.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 05-02-2013, 10:37 PM   #3
redbaron1
that is the best i'v seen so far the dealer did not have an answer for it they said they would have to look at it they had not seen the problem before. and that the parts might not be avallable that they only make some parts for 10 years unless they are real popular. the manual should help. I looked at it real quick temp was 40 with 40mph wind and it is out side. Looked at alldata & Miitchell not very good info.
Thank You
Old 05-29-2013, 08:20 PM   #4
redbaron1
had to replace column what ever holds the two shift tubes was not there they just moved in side each other. next time I'll put a screw in it.
thank you
Old 05-30-2013, 09:31 PM   #5
Chris Stewart
AF - Advisor
Thanks for the update!
