Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-10-2012, 09:10 AM   #1
Black_Blade
What is purpose of capped off brake hose?
While checking things out under rear of my truck, I noticed that the the brake line branches out three ways at the rear axle. One line to each rear wheel and one length of rubber line that is capped off. Never seen that before, just wondering why that is there?
Black_Blade is offline   Reply With Quote
Old 09-10-2012, 11:31 AM   #2
danielsatur
Re: What is purpose of capped off brake hose?
Do you have ABS?
danielsatur is offline   Reply With Quote
Old 09-10-2012, 11:34 AM   #3
jpb53
Sounds like you are describing the diff vent.
jpb53 is offline   Reply With Quote
Old 09-10-2012, 11:38 AM   #4
Black_Blade
The reason figued it was brake line, the main brake line from front comes into a little block, that has three offshoots, one to each rear wheel and this third hose that is about two foot long, it was tucked up under the spare tire..
Old 09-10-2012, 11:40 AM   #5
Black_Blade
Originally Posted by danielsatur View Post
Do you have ABS?
Honestly, not sure, never thought to check. Will do tonight when I get home.
Old 03-26-2013, 12:53 PM   #6
vizial
that is your diff vent,...that "block" is bolted to the diff with a special hollow bolt with a barb fitting for a lenth of hose to vent the diff above any water you might run through...
vizial is offline   Reply With Quote
