| Latest | 0 Rplys |
Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
07-19-2012, 02:53 AM | #1 | |
87 blazer wont start
It turns over but wont start, i have changed the fuel pump, fuel filter, injectors, and i also put new connectors for the injector, and new plugs. But still will not start???? Any help would be great, thanks.
1999 k1500 350 hd tranny 8 inch lift 35" tires |
07-19-2012, 08:19 AM | #2 | ||
AF - Advisor
Re: 87 blazer wont start
Check and comfirm good fuel pressure. Does it have injector pulse cranking?
07-23-2012, 06:04 PM | #3 | |
07-24-2012, 08:47 AM | #4 | |
AF - Advisor
07-24-2012, 09:16 AM | #5 | |
How do i check for the injector pulse??
07-24-2012, 09:52 AM | #6 | |
AF - Advisor
The Following User Says Thank You to MT-2500 For This Useful Post: |
mhowe1182 (07-24-2012)
07-24-2012, 07:27 PM | #7 | |
I checked all those things and they were fine, i took the fuel off and had someone turn the key on and i wasnt getting any gas out of it, i have put a new pump in like two weeks ago and a new filter.
07-25-2012, 01:20 AM | #8 | ||
AF - Advisor
Just turning key on is not a good fuel pressure test. Just. Key on only gives the fuel pump a 2 second prime up. May not be enough time to build up proper pressure You need to check for fuel pump running and for proper pressure with engine cranking. Does it run on engine cranking and what is fuel pressure?
mhowe1182 (07-25-2012)
07-25-2012, 01:25 AM | #9 | |
I think i might gotten the pump with low psi, i was looking at it and it says 12psi and i think i need 60 psi, so i will check the pressure tomorrow, and get back to ya..
