www.camargotransmission.com
Services and Certifications
Our primary service is automatic and manual transmissions, along with work on transfer cases and rear ends. Our staff of technicians are fully trained and certified by both ATSG and ASE and adhere to their code of ethics.
Our builders are sent to conferences annually to ensure that they are aware of and up to date on the latest techniques and problem solving solutions to continue to give you the best service possible.
Diagnosis and Repair
Every transmission problem is unique, and therefore, must be evaluated on an individual basis. With this in mind, we need to have your vehicle at our facility to accurately and efficiently diagnose it.
We will always try to present you with several options in regards to the repair of your vehicle, so that you can make a decision that is right for you.
We will only recommend services that we feel are in the best interest of you and your vehicle.
We also offer electrical diagnosis and use the latest techniques and equipment to give you an accurate diagnosis. From older models to the current applications found on the dealer lots.
