Go Back   Automotive Forums .com Car Chat > Lincoln > Navigator
Old 03-02-2012, 02:11 PM   #1
BEDAGGETT
98 5.4 lt rlincoln navigator heater issue
I have a 98 5.4 litr navigator replaced thermo, flushed, filled, gttn rdy to back fluch, hoses dont get hot neither does engine temp any guesses, just started blowing semi warm air
BEDAGGETT is offline   Reply With Quote
Old 03-02-2012, 04:41 PM   #2
DeltaP
Re: 98 5.4 lt rlincoln navigator heater issue
You probably need to purge the air out of the cooling system.
DeltaP is offline   Reply With Quote
Old 03-02-2012, 05:52 PM   #3
BEDAGGETT
WE HAVE TRIED THAT TO SEVERAL TIMES, I FORGOT TO MENTION NO OVERHEATING OR LEAKING EITHER. I SAW A SITE THAT SAID SOMETHING ABOUT A METAL HOSE LEADING FROM BACK OF ENGINE TO WATER PUMP COULD THIS BE IT CAUSING MY PROBLEMS
Old 03-02-2012, 06:17 PM   #4
aleekat
New thermostadts have been know to be bad out of the box. Sounds like its stuck open
aleekat is online now   Reply With Quote
Old 03-02-2012, 07:08 PM   #5
BEDAGGETT
Put 2 different ones in 1st buy me 2nd buy mechanic
Old 12-28-2012, 12:59 PM   #6
jjmtuttle
Does it have rear heat? You have a door in the dash the separates cold and hot. Mine is stuck on hot yours could be stuck on cold! Common problem on older navi's and expeditions. YouTube it.... Good luck hope this helps
jjmtuttle is offline   Reply With Quote
97 dakota heater issue davida6302 Dakota 1 01-12-2011 12:54 PM
1999 2.4 Quad 4 Issues thrashpirate Grand AM 4 05-08-2009 08:53 PM
Replace 4.6 with 5.4? nascartony05 F Series 2 04-11-2008 01:04 PM
'93 C1500 4.3, 5 speed now has starter issue jshort74 C/K 7 06-26-2007 03:54 PM
Switch 4.5 to 5.0 in 88 Caddy? '88 Caddy Deville 1 05-25-2007 11:16 AM
