Go Back   Automotive Forums .com Car Chat > Saturn > Ion
Old 10-16-2011, 06:40 PM   #1
lisams901
2006 Saturn Ion Won't Start
I have a 2006 Saturn Ion 3 Quad Coupe. I haven't been able to start it since Oct. 6.
It started fine all that day then I went out to start it and nothing. It doesn't make any of the typical noises when your car won't start like the clicking or sound of it trying to turn over. It's like you didn't turn the key at all. Then after you stop trying and take the key out, it makes a noise like a car alarm going off.
I haven't been able to get anyone to look at it yet so I've been using a rental for the past week. I don't think it's the battery because even a week later when I try to start it all the lights and everything comes on strong. I wanted to try to get the battery to Auto Zone just to test to make sure it's not that, but I can't get it out.
My question mainly though is does that car alarm noise mean anything? Only one before did the car not start (it was like 10 degrees out) and it did not make that noise then.
lisams901 is offline   Reply With Quote
Old 10-16-2011, 07:41 PM   #2
FishFind
One Hot Shot
Re: 2006 Saturn Ion Won't Start
not sure but if you know that your battery is good then I am guessing Starter, Wires going to your starter, fuse or relay for the ignition or starter, or a bad ignition.
Check fuses for ignition and for the starter.
FishFind is offline   Reply With Quote
Old 12-19-2011, 01:20 PM   #3
lakefork
lakefork's Avatar
its the ignition switch my uncle had the same problem and we replaced the ignition module and it fixed the problem 45 dollars and you have to program the new switch my turning on the ignition and waiting about 30 minutes for the computer to recognize the new switch
lakefork is offline   Reply With Quote
Old 02-23-2012, 01:19 PM   #4
b1957r
Thumbs up Re: 2006 Saturn Ion Won't Start
Got a 97 saturn sc2, went to start nothing, no sound when key was turned. Had no interior lights, no power windows, no power door locks, and no door chimes. Had lights on dash and radio, still nothing. Went to passenger side fuse panel, popped it off and looked on back of panel, took out the one that is a 10 amp fuse marked body and replaced the new fuse and lord and behold it cranked! Hope this will work for some of yall that are having the same problem. .89 cent 10 amp fuse, and my car started!
b1957r is offline   Reply With Quote
1997 Saturn SL not starting DebbiR SC/SL/SW 19 07-17-2016 09:25 PM
2006 Ion Won't start sometime's, then will later. saturnsucks Ion 7 10-22-2013 11:09 PM
99 Saturn SL Won't Start! turtleisland SC/SL/SW 5 08-13-2009 10:52 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
Rear Brakes On 2006 Saturn Ion 2.4 L papanots Ion 0 11-13-2008 09:52 AM
