Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 07-17-2011, 05:42 PM   #1
robiwankenobe
Intermitent electrical problem on 2003 Grand Caravan
All the electrical components that are controlled by the ignition key/switch (radio, power windows, wipers, AC/fan) sometimes don't work when I turn the van on. However, when the key is turned back into accessories position, everything works - never a problem then. I had the ignition switch replaced a few months ago and that seemed to help (didn't occur as often) but now it's back to the way it was before. Just about every time I need the wipers (when it rains), they don't work nor do any of the other things I mentioned previously. Any recommendations on where to start troubleshooting this? Thanks.
robiwankenobe is offline   Reply With Quote
Old 07-18-2011, 07:48 PM   #2
mishalah
mishalah's Avatar
Re: Intermitent electrical problem on 2003 Grand Caravan
Did you have the combination switch or module replaced or just the ignition switch itself? The wipers are controlled by the BCM underneath and the combo module on the column.
mishalah is offline   Reply With Quote
Old 07-19-2011, 12:17 AM   #3
robiwankenobe
Just the ignition switch. The person who put it in said that if the ignition switch didn't fix it I'd probably need to replace the BCM at about $700. Thought I'd try to check current etc before I drop that kind of money but wanted to ask for advice on where to start before I do. Would the bad combo module also explain why the radio/windows/AC don't work as well? Everything seems to work fine until I use the wipers (when it rains), then they all go out (i.e. - seems like the use of the wipers is setting if off).
Old 07-04-2013, 09:27 AM   #4
catkoot
Smile Re: Intermitent electrical problem on 2003 Grand Caravan
2001 dodge grand caravan 210000 M
Same issue here accessories don't work when I turn the van on. However, when turned back into accessories position, everything works also when i turn the a/c on it comes back on and off !! I changed the ignition switch but it didnt fix the issue !!!
catkoot is offline   Reply With Quote
Old 07-04-2013, 03:05 PM   #5
Erin T
Just had same type problems, my alternator had a bad rectifier. Check to see if you have any AC voltage while running or unplug the alternator to test it.
Erin T is offline   Reply With Quote
Old 08-02-2013, 05:12 PM   #6
catkoot
Talking Re: Intermitent electrical problem on 2003 Grand Caravan
So i took my 2001 Grand caravan to the dealer to fix the acc issue which is when start the car doesnt work then it keeps turning on / off , they called me after two days and said its the electric harness issue so they cleaned n fixed the wires cuz the battery was leaking and thats what caused the issue n charged me $400 !! I paid n got into my car to find out the problem is still the same !! so they refunded me the $400 n kept the car n called m,e back after a day to say it " found that no proper communication from PCM n recommenda new PCM $1140 + tax !!! which is to much money to fix a small issue !!! so i took my car free of charge .
I dont think its PCM issue but who n\knows !! so what you guys think the right thing to do !!!
Intermitent starting problems Driver2001 Grand Marquis 3 10-25-2010 06:56 PM
85 grand marquis - electrical problem aray4al Grand Marquis 5 06-25-2010 06:39 PM
Intermitent electrical problems gahargrove Venture 0 12-17-2005 11:32 PM
2003 Grand Caravan 6cyl engine noise nipski6 Caravan | Voyager 1 10-16-2004 11:06 PM
Intermitent Electrical Problems blueboxter Boxster 0 10-09-2002 06:49 PM
Tags
electrical , power , radio , windows , wipers
