Go Back   Automotive Forums .com Car Chat > Ford > Aerostar
Old 06-03-2011, 06:56 PM   #1
bsr2002
Angry Oil Pressure
I was driving my Van outta town when I started smelling oil burining, I'm gussing it might have sprung a leak and was dripping on the manifold. I stopped at the store and put some oil in and started heading home.
So I'm on the fereeway almost home, still smelling burnt oil... All of a sudden my oil preasure gage goes to zero and lots of oil on the ground had to pull over and have it towed home.
I'll jack it up tomorrow and take a look, any ideas as to what happened?
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
bsr2002 is offline   Reply With Quote
Old 06-04-2011, 04:33 PM   #2
Knifeblade
Re: Oil Pressure
Too many to list. Jack it up, put in some oil, and start the engine, see where it comes out of. Also, pull the engine cover off so you can see the back of the engine from the top.
Knifeblade is offline   Reply With Quote
Old 06-14-2011, 06:18 PM   #3
FordMan59
Re: Oil Pressure
The first thing I'd check is that the oil filter is tight and that it's not leaking around the oil filter gasket. Oil pressure sending units often crack causing a leak too.
FordMan59 is offline   Reply With Quote
Old 07-12-2013, 02:06 AM   #4
bsr2002
Re: Oil Pressure
Sorry, it's been about a year and I finally started checking things out. It's been sittin in the driveway so I suppose there is some build up. I put oil in it and started it up and it's holding pressure and the only leak I'm seeing so far is coming from the back of the oil pan.
So can't tell if it's just the oil pan or the main seal...
Old 11-07-2013, 03:09 AM   #5
bsr2002
Question Re: Oil Pressure
Here is a video of the leak, I'm not understanding why it's not gushing out like it did initially. Looks like a trickle now, it only seems to leak while the motor is running.
This is after about 20 minutes of idling on my driveway...
http://www.youtube.com/watch?v=rNxWRpWyiLE
Old 11-19-2013, 05:32 AM   #6
Allenriddoch
Re: Oil Pressure
Jack it up, and start the engine again to find out the leakage. Fix it soon before it gets worse.
Allenriddoch is offline   Reply With Quote
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 01:08 AM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 09:33 AM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 06:52 PM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 01:37 AM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 08:27 PM
