| Latest | 0 Rplys |
04-11-2011, 01:32 PM | #1 | |
Suzuki Every specs
The standard specifications of the Suzuki Every are as follows:
Car Styling: · Engine location is front · Weight is 1929 pounds (874.98 kg) · Drive style is front wheel Performance: · Top Speed of 135 km per hour (83.907 mph) Engine: · Cylinders are 4 · Engine configuration is S style · Induction or aspirations are normal · Valves are 16 valves in total, with 4 valves per cylinder · Horse power is 69 BPH (50.784 KW) at 6000 rpm · Valvetrain is double overhead camshaft (DOHC) · Torque of 70 feet pounds (95 NM) at 3250 rpm · Compression ratio of 9.30:1 · Horse power to weight ratio is 28.0 pounds per horse power Transmission Information · Transmission is automatic · Gears are four in total · Final drive is 3.93 Production figures · Total production of Suzuki in 1999 is 14,610 Dimensions: · Seating capacity of passenger and driver in total are 4 Exteriors: · Length of car is 133.9 inches (3401 nm) · Width of car is 62.1 inches (1575 nm) · Height of car is 67.1 inches (1704 nm) · Wheelbase of car is 91.9 inches (2334 nm) · Front track of car is 53.5 inches (1359 nm) · Rear track of car is 53.3 inches (1354 nm) Steering Wheel The styling of steering wheel was rack and pinion style |
05-09-2012, 01:01 AM | #2 | |
Re: Suzuki Every specs
thank you for the information. It really helps me a lot.
“In three words I can sum up everything I've learned about life: it goes on.” ― Robert Frost |
