Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora
Old 02-09-2011, 10:51 PM   #1
jetta_help_needed
2001 gls battery drain
Imagine this. Another problem with a 2001 Jetta (4-cylinder GLS) and a parasitic battery drain. Details below, and any insight you can provide would be helpful.
Condition and Tests
* car killed three batteries in two years (no problem starting in summer, but winter breaks them).
* charged existing battery to 12.4 volts, disconnected it, and then reconnected one week later to reveal 12.4 volts. (should be 12.6 at full charge, sure, but only got to 12.4)
* connected battery overnight, 12.4 volts dropped to 11.8, no start.
* same result as above with brand-new battery (including 12.4 volt limit on full charge and subsequent voltage drop).
* multimeter says alternator charging normally (steady reading of 14.5 with car running, tested on both batteries)
* set multimeter to 10 amps, and readings jumped around - 0.5, 0.85, 1.1 - then quit to 0.0 with 10-amp fuse blown (verified with continuity test on fuse pulled from multimeter).
* after three days with battery disconnected, placed a 12-volt test light (0.4-amp draw) in-line, and pulled everything I could think of one-by-one --- all fuses (battery fuses and interior panel), Monsoon audio (radio, amplifier, and CD), and alternator --- but test light (rather bright) would not go out.
Observations (some odd)
* radio retains presets, even with week-long battery disconnect. (unheard of, in my experience)
* CD player, a usual suspect, is factory but installed aftermarket (and removing it didn't make light go out)
* test light glimmered - brighter, dimmer, brighter - not a steady consistent light.
* with fuse 42 (radio, 25-amp) removed, test light would glimmer in sync with loud clicking in the dash behind the odometer: louder clicks = brighter light, quieter clicks = dimmer light.
* glove box, trunk, and interior lights go out when glove box or trunk closed and/or car turned off.
* all auto locks and windows work properly, but can hear what sounds like a window motor trying to wind when doors are unlocked (not CD player).
jetta_help_needed is offline   Reply With Quote
Old 02-09-2011, 11:59 PM   #2
danielsatur
Re: 2001 gls battery drain
Do all the bells & whistles work , other than battery drain?
Is there three fuse blocks on this car?
Try isolating the relays!
danielsatur is offline   Reply With Quote
Old 02-10-2011, 12:56 AM   #3
jetta_help_needed
yep, all bells and whistles work.
two fuse blocks that I could find - (3) 30-amp fuses on battery housing, the few dozen on driver-side inside panel. is there a third?
good idea to isolate relays, but aren't they generally defaulted to "off" position?
two more observations tonite:
* running lights remain on even when the parking break is engaged while car is started or running
* key cannot be removed from ignition unless forcefully placed in 'park' - generally takes two or three times slamming into 'park' to remove key.
TCM maybe?
Old 02-10-2011, 03:24 PM   #4
danielsatur
The fuse should protect the relay and circuits.
Some unswitched relays get the battery with the ignition switch off.
Also some control modules have a capacitor to act as a small battery to give a small battery to the control module to save data and control with the ignition switch off.
If a capacitor is leaking, it could cause drainage on a battery.
Picture the security Alarm ON needing a battery with the ignition switch off!
Because all the bells + whistles works, you might need to Isolate the control modules by
a disconnect.
Old 02-11-2011, 05:16 PM   #5
jetta_help_needed
good advice and explanation.
will try isolating relays and modules with test light (and leave the multimeter out of it) and let you know.
Old 02-11-2011, 05:31 PM   #6
danielsatur
Try to get the Park pos with the ignition key removal problem fixed ASAP!
There might be a broken, or loose sensor/switch, that's not signalling the
TCM your NOT in the parked pos, so you can't have your keys.
Old 02-11-2011, 05:49 PM   #7
jetta_help_needed
agreed. guessing loose sensor or switch and definitely don't want to lose the keys.
Old 02-18-2011, 01:37 AM   #8
jetta_help_needed
thankfully, first thing is that TCM does not seem to be the problem. guessing it's the key - switchblade key has trouble with removal, valet key removes easily under same conditions.
however, testing has revealed additional information.
* re-tested all interior, driver-side fuses against test light, and no problem revealed (test light stays on).
* removing power from S176 fuse/wire on top of battery turns test light off. this wire send power to the relay.
* isolating relays does not relieve drain on battery - test light continually bright.
* isolating second-from-left 30-amp post at bottom of relay (two red wires) does relieve test light. split those two and have a long list of what works and what doesn't.
2006 Grand Prix Battery Drain wratchetjaw Grand Prix 9 12-20-2010 05:18 PM
2001 Olds Alero Battery Drain Issue Xenokira Alero 3 04-20-2009 11:04 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 07:30 PM
2001 Jetta Battery Drain texasjettaowner '97 - '03 1 05-08-2006 09:36 PM
2001 E350 battery drain Harlem E Series 0 01-10-2006 09:33 PM
Tags
battery , drain , electrical , problems
