| Latest | 0 Rplys |
Non-Performance This is the place for all interior, exterior, and general non-performance modifcations. |
01-21-2011, 03:22 PM | #1 | |
KILL SWITCH die time?
I want to hook up a kill switch to my fuel pump. How long would it take to starve off the fuel and die? 1995 Ford 5.0 fuel injected. I am deciding between a kill switch to either the ignition or the fuel pump. Any info would be welcome!
01-21-2011, 05:10 PM | #2 | |
Re: KILL SWITCH die time?
Do it to the fuel pump. Killing the ignition only and trying to start the engine with the kill switch off will flood the engine. If you kill the ignition while running, you also leave unburned fuel in the cylinders.
2000 Mercury Grand Marquis LS - 119k / 14.89s @ 92.11MPH [ pictures | videos ] > Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok > Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB > BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms > CVPI aluminum driveshaft |
02-21-2011, 07:14 AM | #3 | ||
Stanger
As mentioned, I would kill the fuel. Your car will probably run for about 10-20 seconds then stall out.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
02-21-2011, 10:15 AM | #4 | |
10-20 seconds? I've never gotten more than about 1 second when I pull the fuse for my fuel pump with the engine running to de-pressurize the lines. The pressure drops off very quick, even at idle.
02-21-2011, 10:48 AM | #5 | |
Stanger
Giving lee way, I've seen a Taurus run for 10 seconds once the inertia switch was tripped.
Tags |
kill |
