Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 01-09-2011, 10:20 PM   #1
plmnwater
05 Civic Coolant flows to overflow, doesn't come back
I have an 05 Civic Ex, and noticed a while back that the coolant was low. I kept thinking that I had a leak somewhere, but have so far not been able to locate one. I would top it off every week or two, and then all would be fine for a while.
After doing this for a while, I noticed that the overflow tank was getting full. It seems that coolant is flowing into the overflow, but is not flowing back into the radiator once it cools down. I replaced the cap, hoping it was simple. That didn't help. I checked the hose that leads to the overflow. Coolant flows easily both directions.
I did notice that once the engine is completely cooled down, the cap still holds vacuum. When I take it off, there is a very noticeable sucking of air into the radiator.
It has never overheated, it's not leaking coolant anywhere that I can see, the exhaust doesn't seem to be smoking at all. Any suggestions as to where I should start?
plmnwater is offline   Reply With Quote
Old 01-10-2011, 08:18 AM   #2
snshddog
Re: 05 Civic Coolant flows to overflow, doesn't come back
Sounds like its the rad cap. The rubber can swell over time and cause this.
snshddog is offline   Reply With Quote
Old 01-10-2011, 03:17 PM   #3
plmnwater
I just replaced the cap about two weeks ago. It is still having the same issue.
Old 01-25-2011, 05:40 PM   #4
fejetmech
Did you replace the cap with a Honda product or generic cap from an auto parts store?
fejetmech is offline   Reply With Quote
Civic loses all electrical power-comes back later spraydu '96-'00 Civic 2 06-02-2010 06:38 PM
P0340 at start-up, doesn't come back on while driving. mike2004tct Problem Diagnosis 3 03-11-2010 08:23 PM
WTB: 2006 civic coolant overflow tank f22aRacer '06+ Civic 1 10-24-2006 12:12 AM
Coolant fan doesn't come on... bhoward86 Probe 9 03-29-2005 10:04 PM
I hope he doesn't come back... Diesel2NR Stress Release 12 06-13-2004 09:06 PM
Tags
coolant , overflow , radiator
