Go Back   Automotive Forums .com Car Chat > Toyota > Celica
Old 12-20-2010, 08:46 AM   #1
jsaye2002
Sounds while turning at slow speeds
I have a 90 Celica GTS thats a 5 speed, and the last month or so when going at slow speeds and turning, it almost sounds like tires rubbing bad on the fenders. But they are clearly not. There is also some resistance too when turning. Not sure if that helps. But I've checked the PS fluid and its full and not leaking. Any suggestions?
jsaye2002 is offline   Reply With Quote
Old 12-21-2010, 09:30 AM   #2
jsaye2002
Re: Sounds while turning at slow speeds
any suggestions?
Old 12-23-2010, 09:29 PM   #3
flashlight
Have you checked the cv joints and bearings? It could be that the grease in the bearings has worn itself out. The only way that I know of to check the lack of grease is to take the hub off.
flashlight is offline   Reply With Quote
