Go Back   Automotive Forums .com Car Chat > Oldsmobile > Intrigue
Old 12-16-2010, 04:27 PM   #1
daddyoscott
Question Popping Driver Side Wheel In Reverse
1998 Intrigue - 158,000 miles. today I put the car in reverse to back out of the driveway and turing the wheel to the right in reverse, I heard and felt a pop in the driver side wheel, I continued the reverse without any throttle and the popping and binding stopped the car. I gave it a little gas and the wheel popped again but began rolling. Put the car in drive..........smooth and quite. I was told 60,000 miles ago the struts were shot and just put new brakes and rotors on 3,000 miles ago. Should I start with replacing the HUBs, then CV's and on......until I've rebuilt the entire front end?
daddyoscott is offline   Reply With Quote
Old 12-17-2010, 01:07 AM   #2
LittleHoov
LittleHoov's Avatar
Send a message via AIM to LittleHoov
Re: Popping Driver Side Wheel In Reverse
Check out your caliper mounting bolts, one of them might have come loose, particularly the front one since it only happens in reverse. Just check out the brakes in general.
I had a similar issue after swapping to the 12 inch rotors, I didnt get the caliper mounting bracket bolts tight enough...but you shouldnt have had to dig that deep into the brakes if you just did pads and rotors.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
LittleHoov is offline   Reply With Quote
Old 01-21-2011, 05:39 PM   #3
harmankardon35
probably your strut mount bearing/plates. get them replaced along with your struts. not a big safety issue but it will get louder. they are designed to twist with the steering but they get worn and 'caught up' causing clicking/popping especially the first turn in reverse...
harmankardon35 is offline   Reply With Quote
95 k1500 wheel driver side wheel scottinachevy C/K 8 10-29-2009 07:29 PM
Renault Clio noise from drivers side wheel - help!! adetemp1 Clio/Clio II/Clio III 3 10-05-2005 01:53 PM
knocking sound in driver side wheel well beatybaby '97+ 4 12-23-2004 01:48 PM
91 Accord Drivers Side Wheel "Metalic Clank" on Bumps amistad6 Accord/TSX/Accord Hybrid 3 10-04-2004 02:03 PM
Rear driver side wheel rolling tight....smoke/burning smell coming from the wheel mihird Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 8 08-06-2004 05:55 PM
