Go Back   Automotive Forums .com Car Chat > Geo > Metro
Old 10-19-2010, 01:38 AM   #1
chikilin
Question Head Cylinder difference in between 98 and others with square timing belt tooth
If you kindly tell me the difference in between cylinder head with a square and rounded timing belt tooth .
my Problem is : I have a 98 chevy metro and with no engine in, but I have the block and the cylinder head separate and the cylinder head has the camshaft sprocket with the square tooth and the block has the round tooth with the sensor at the bottom and at front of the engine, I know the timing belt difference but is a way to use this head by just changing the camshaft sprocket and if yes would be good to have those high performance whose are selling every where
Any help I would appreciate a lot
Kind Regards Chikilin
chikilin is offline   Reply With Quote
Old 10-19-2010, 05:16 AM   #2
Woodie83
Woodie83's Avatar
Re: Head Cylinder difference in between 98 and others with square timing belt tooth
No difference in the head unless it's an XFI head, then the cam would be special for high mileage. You need the rounded tooth sprocket.
>would be good to have those high performance whose are selling every where<
Wow, going to have to guess here, but sprockets with advance built in and cams with either high performance or high mileage characteristics are available from 3Tech, he knows more about the Suzuki G10 than Suzuki does.
http://geometroforum.com/pages/3Tech
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Woodie83 is offline   Reply With Quote
Old 10-19-2010, 09:14 AM   #3
chikilin
thanks m8 that relly helps me now ,I'll get one of those from 3tech. Cheers
Differences between '05 and '06 1.6 Engines? edr_bug Aveo 0 08-07-2009 12:51 AM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 04:28 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 05:30 AM
Difference between a pic with or without flash Neutrino COMPLETELY off-topic 5 10-14-2004 04:15 PM
RB26 head on an RB25 and other stuff.... Nalfein 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 6 12-01-2003 07:50 PM
