| Latest | 0 Rplys |
10-01-2010, 10:13 PM | #1 | |
Banned
Blower Motor
Hello,
'95 Lumina APV. The blower motor doesn't work. I removed the blower motor and ran battery power to it and it worked fine. I put it back into the van and put a volt meter to the connection and was getting power to the motor. I plugged it back in and it worked until I turned the switch off. When I turned the switch back on, the motor wouldn't work. Is the switch more likely to be at fault or could the blower motor resistor work intermittently? Thanks! |
10-02-2010, 12:31 PM | #2 | |
Re: Blower Motor
Suspect the high speed relay.
www.avigex.ca/xport/heaterrelay.jpg All current to the blower is fed through this relay, whether or not it is on high speed. www.avigex.ca/xport/hvac_diagram_front.jpg. Use of high speed for long periods will fry the relay or socket contacts.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
10-02-2010, 01:20 PM | #3 | ||
Banned
Re: Blower Motor
Thank you! 2 questions please. 1) Would the high speed relay allow power to the blower motor sometimes and not at others (intermittent)? Would not the switch do the same if it is on the fritz? And 2) Where can I buy one. I have checked the web sites (RockAuto.com, AdvanceAuto.com and even [gag] Autozone.com) and can't seem to find a high speed relay. Thanks again, Roland |
10-02-2010, 06:08 PM | #4 | ||
Re: Blower Motor
NO idea...I'm in Canada.
11-19-2010, 01:05 PM | #5 | ||
Banned
Re: Blower Motor
