Go Back   Automotive Forums .com Car Chat > Mazda > General Discussion
Old 09-16-2010, 10:21 PM   #1
eliphino
mazda 626 cooling fan and ac problem
1999 mazda 626 4cyl manual trans, high mileage. High side AC pressure is 425 at 2200 rpm. Low side 35. The AC fan is coming on but the other fan doesn't seem to be cycling. Motor is good but no power to motor. Any suggetion for the fan and could this be the cause of the high pressure on the high side? Thanks
eliphino is offline   Reply With Quote
Old 05-07-2012, 06:45 AM   #2
tobiasschnell
Re: mazda 626 cooling fan and ac problem
Hello,
sorry to say but i have not faced this problem any time.
tobiasschnell is offline   Reply With Quote
Old 06-10-2012, 04:25 PM   #3
Mx5guy
Send a message via AIM to Mx5guy Send a message via Yahoo to Mx5guy
Well that problem is actually very easy to solve, you problem should be a bad coolant temperature sensor is the one that monitors the coolant temperature and activate the fan as often as needed, you will usually find this sensor close to the inlet water hose or thermostat housing (water outlet)
If you want to be sure that is the problem before you change the sensor and spend your money you can perform a little test take the plug off the sensor it has two wires get a piece of wire and jump them together with the ignition switch open , if fan starts after you close the circuit with the jumper wires you can be sure your sensor is gone. Good luck buddy. Blessings!
Mx5guy is offline   Reply With Quote
Tags
1996 , 626 , mazda
