Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Old 07-02-2010, 10:03 AM   #1
Techniker
Do It Yourself ATF Flush
I am going to do the following procedure to change out my transmission fluid since it has turned brown. (I took it to a transmission shop where they dropped the pan and replaced the filter and fluid. They said the transmission fluid was fine, just old, but I don't think it could hurt to replace it.) I drive a 1995 Toyota Camry V6 XLE with 141,000 miles.
My question is this: Is there any problem with removing the outlet line from the transmission and placing it in a bottle of new ATF? Does the transmission even have that much suction or would I have to make sure the hose is long enough that I can have the supply line above the level of the transmission? Should I even do this at all? I really think the transmission needs to be flushed because I have thrown a sticking solenoid valve code twice. There is now some Seafoam TransTune in there and I think that should be removed if nothing else.
TRANSMISSION FLUSH PROCEDURE
Q: How can I flush my transmission fluid without bringing it to a shop?
A:
You can actually change virtually all the fluid in the system using the following method. We have 5 Toyota's in the family, and I have done this to them all at least once.
It takes about an hour. Use whatever fluid is recommended on the dipstick, or in the manual. Our Camry's and Corolla's take Dexron, but the Celica takes Toyota Type IV fluid, available only from Toyota, at about $3.50/qt. Use what's recommended, or you'll be sorry. It's still less expensive than having it done.
1. Drop the pan*, drain the fluid, replace the filter, and reinstall the pan as you usually do.
2. Add 3 quarts of fluid. (or however many quarts of fluid are drained from the pan).
3. Remove the fluid return line at the transmission (usually the upper of the two lines), and place it into a one-gallon milk jug or similar semi-transparent container. You may want to place the container in a box with rags around it so that it doesn't spill.
4. Start the engine, and let about a quart or so of fluid get pumped into the milk jug (about 10-15 seconds).
5. Stop the engine, and add a quart of fluid to the transmission.
6. Repeat steps 4 and 5 until you get new fluid out of the drain line.
You'll use about 8-10 quarts of fluid total, including the 3 you put in at the beginning, so you may need more than one milk jug.
7. Reinstall the drain line to the transmission, start the engine, and check for leaks.
8. With your foot on the brake, put the transmission in each gear, then into Park.
9.Let the car down and check the fluid level on the dipstick. Add fluid if needed to bring it up to the proper level.
10. Take it out for a test drive, and check the fluid level again.
(*One caveat is that it is not nessary to drop the pan. Removing and replacing the filter is not necessary. It is more or less just a screen that doesn't get plugged unless your clutch plates shread or something equally traumatic happens. Brian R.)
Techniker is offline   Reply With Quote
Old 07-02-2010, 01:50 PM   #2
Airjer_
Airjer_'s Avatar
Re: Do It Yourself ATF Flush
The transmission will not suck new fluid out of a bottle into itself. It will have to be added through the dipstick tube.
Airjer_ is offline   Reply With Quote
Old 07-07-2010, 01:49 AM   #3
curtis73
Professional Ninja Killer
curtis73's Avatar
Even the most expensive solenoid on a toyota A540 is the linear which is about $138. The cheapest is the lockup solenoid at about $34.
Why not just fix the problem instead of spending a couple hundred trying to engineer a flush machine?
Dragging people kicking and screaming into the enlightenment.
curtis73 is offline   Reply With Quote
Old 07-07-2010, 01:55 AM   #4
Techniker
That's kind of the problem. I can't figure out what the problem is. Everything seems to be normal, with the exception of the error code which only comes on every few hundred miles. I can't find a pattern.
In case anyone is wondering, I performed the ATF flush and it went perfectly. I now have a nice pink ATF.
-Techniker
Tags
atf , camry , diy , flush , transmission
