Go Back   Automotive Forums .com Car Chat > Nissan > Nissan Cima | Nissan President | Infiniti Q45
Old 06-30-2010, 04:06 PM   #1
darlenestar
91 Q45 No Start
Hello,
Purchased a 1991 Q45 with 170,000 miles a few months ago. The car was running fine. Went to family's last night and several hours later the car won't start.
Here's what has been tried:
Starter is turning over. Checked for fuel by taking off the line between the fuel filter and the fuel rail. Pulled and reinserted the fuel injector fuse for a "flood condition".
Any suggestions on how to resolve the no start problem or what else I can check before resorting to a tow and garage.
I need this car running asap. Thanks in advance for any input.
Darlene
darlenestar is offline   Reply With Quote
Old 09-29-2010, 02:21 PM   #2
maxnix
maxnix's Avatar
Re: 91 Q45 No Start
You must do a fuel pressure test first to affirm the pressure is sufficient at idle (34 psi) and WOT (43 psi).
After you post a maintenance history, then we can triage the cause.
Brian
1995 Q45 & Q45t 2000 Q45
maxnix is offline   Reply With Quote
