| Latest | 0 Rplys |
04-08-2010, 12:55 AM | #1 | |
1979 Chevy C10 Pickup
I just bought a 1979 Chevy pickup. It has a 350 in it but the transmission is not right...The previous owner had lowered it and put a transmission from a 1948 chevy car...not sure what kind of car though..What I really need to know is what kind of transmission will fit in it right or can i repair the trany that is in it to fit up right...Could use the help...One more thing doesn't a 3 on the tree mean stick or does it mean automatic?
04-08-2010, 09:28 AM | #2 | ||
AF - Advisor
Re: 1979 Chevy C10 Pickup
Yes 3 speed standard with shifter on stering column. Does it have a std or auto transmission now? What is not right on transmission? Are you looking to put a auto or std stick or floor shift back in it? The 350 engine bolt pattern should fit all older or newer GM V8 engines.
04-08-2010, 01:58 PM | #3 | ||
04-08-2010, 03:27 PM | #4 | ||
AF - Advisor
Not unless it is already a 4W. 4W and 2W transmissions are different. If a good standard already in it. Why not just fix you linkage?
04-08-2010, 03:37 PM | #5 | |
The reason i asked about automatics is because i didnt know 3 on the tree come in that year of trucks...The man wasn't real spacific about the 3 on the tree...fixing the linkage would be fine but I wasn't sure if you could if it didnt line up quite right...is there a kit i need to buy on top of buying the linkage?
04-08-2010, 04:30 PM | #6 | ||
AF - Advisor
But most can be adjusted up tighter and shifting linkage rodes centered. See if you can adjust it up. Let us know how it goes.
04-09-2010, 11:33 AM | #7 | |
AF - Advisor
Back when I was kid we always change the 3 on tree shifters over to a good hurst floor shifter with dual glass packs.
Good fast shifts and you could bark tires in second and even 3 gear if you had a hot V8.
