| Latest | 0 Rplys |
#1 | |
I got a 1992 nissan 240sx with the 2.4 SOHC engine.. had to go behind a slack mechanic a re-do his timing job.. when reassembled the car has no oil pressure (warning light on).
Ok so i take off oil pump. fill it with oil. and try again.. still nothing. Next fill the pump with Vaseline.. still no oil.. Ok so i make sure the oil pump/dist shaft is lined up properly. un plug the coil an spin the motor over a bit.. nothing once more.. o an i tried a brand new oil pump with the same results.. used a air compressor to blow out oil passages..all clear. pickup tube is not stopped up(removed oil pan and checked) Can anybody help me out here? ive tried everything i can think of.. Maybe some way of priming the oil pump would help.. thank you--braxton |
#2 | |
![]() Join Date: Jan 2005
Re: 240SX no oil circulation/ pressure
after all that work, im assuming you checked the sending unit?
Tags |
240sx , oil , pressure , pump |
