| Latest | 0 Rplys |
WIP - Motorbikes Post topics for any "Works In Progress" motobikes projects in this sub-forum. |
#61 | |
Re: Yamaha Tech 3 + Laguna Seca
I wish you good luck! :-)
Tibi |
#62 | ||
#63 | |
Thank you John, I should have needed the decal some days ago, 2 layers of decal should have been perfect. I understand your procedure. Today I washed and cleaned all the fairings and they looks good. Tomorrow I will try with a thin layer of x-22 to seal the decal, expecially the chromed one on the front cowl and then I will procede with 2K....
#64 | |
These 3 days worked with 2K. First of all, as I thought, a thin layer of x-22 to protect the decals, expecially the chromed n. 5
![]() Second day the first coat of 2K quite thick and the day after a second coat wet (like water) ![]() ![]() ![]() There is something to make, some dust particles to remove but the big job is done.... ![]() |
#65 | |
Andrea - those body pieces look beautiful - it is like glass. Don't worry about a couple of dust spots they will rub out just fine. The overall look and effect is fantastic. Did the "metalic" number 5 of Edwards lose any metal effect when you put on the clear? From the picture I cannot completely see. Was your X-22 acrylic or enamel? Overall this came out great - I hope mine is half as good. - John
#66 | |
Thanks John the chromed n5 is still chrome...
![]() I used the acrylic x-22. To tell the truth it was not tamiya but Gunze, anyway it's the same paint. |
#67 | |
Hi,
Beautiful work on the monster bike. For the clear part. Did you use gunze mr topcoat to protect the decals? I had a bad experience using 2k clear from zero paints. The clear crawled under the decals. Did you spray a thin coat of gunze or a wet coat. Lesley |
#68 | |
Nice work Andrea! You sparyed the clear very good. I like it!
Did you make some test? How well sticks the 2 k clear over the gunze/tamiya acrilic clear?
Tibi |
#69 | |
@eyckle: I used the aqueos line from Gunze, the same of tamiya X-22 acrylic. I sprayed a thin coat, anyway these paint don't give any problems with decals. It's since many year I use 2K on decal with no problem.
@Tibi: I didn't make any test... ![]() ![]() It seems the 2k sticks well on x-22..... (I hope.... ![]() ![]() |
#70 | |
I started the polishing job, micromesh and compound.... pretty boring...
Assembled the shift linkage: ![]() I have placed a thermoformed (?) tube on the pedal I have filed the pin for the aft tank cover and placed a dummy screw on it (hooby design) ![]() So closing the tanks: ![]() See you ! |
#71 | |
Completed the front cowl too, I'm near the end....
#72 | |
It look's great! Can wait the finish!
Tibi |
#73 | |
looks very good Andrea - how is the Laguna version coming? - John
#74 | |
4 pictures before finish the fairings and close her...
#75 | |
Another problem with Laguna Seca decals....
![]() As you ca see from the pictures the writing SEMAKIN on the left side of the rear cowl is wrong. In the real bike is up and on the right in the decal is on the left.... I thought to make another black shape on which place the white writing but the writing on the decal is... CLEAR!!!! |
