CV axle noise how to tell
citydragon
05-07-2008, 06:35 PM
Tell me if I'm right, if a car makes a clicking/clunking noise when turning right it's likely the passenger side cv joint. Turning left, drivers side cv joint...correct?
Sorry if this sounds lame...I'm not a mechanic and if I was I would be one of the world's worst mechanic.
Johnny Mullet
05-07-2008, 06:46 PM
That sounds right to me. Usually when one is making that kind of noise, the boot is ripped and all the grease slings out. A visual inspection would verify this.
citydragon
05-07-2008, 07:17 PM
Thank you for the reply...
I looked at the boots they seem fine on both sides, no tears, there was a bit of grease at the end of the boot-passengers side though.
I wonder...I don't hear that "steady clicking noise" when turning-typical of a cv joint going bad.
What I'm getting is a clunking/crunching noise when making a regular left turn. It sometimes also occurs when accelerating at slow speed just going straight...faster speeds are fine. I feel it under the driver's side floor. I looked at the ball joints, grabbed them to check for any play, bushings all seem fine.
91Caprice9c1
05-07-2008, 07:30 PM
Maybe have a glance at your motor mounts. Especially the one positioned rear and center.
-MechanicMatt
Johnny Mullet
05-07-2008, 09:26 PM
Wheel bearings?
doug7x
05-12-2008, 10:13 PM
From my experiance, a left CV will knock when turning RIGHT, & vice-versa (the axle on the outside of the turn is the one doing the work, therefore, when under load, will knock if bad)
91Caprice9c1
05-12-2008, 10:56 PM
I'll try that sometime.
FWIW, City: Bad CV joints make an unmistakeable 'clackety-clack.'
-MechanicMatt
citydragon
05-12-2008, 11:16 PM
-MechanicMatt
Yes, very familiar with the clackety-clack...I have the clunk-clunk.
Inner cv joint???...Note below from a description I found on the web
I wonder if mine is the left or right inner cv joint gone bad:
"A "clunk" when accelerating, decelerating or when putting the transaxle into drive. This kind of noise can come from excessive play in the inner joint on FWD applications. A quick way to verify the diagnosis here is to back the vehicle up, alternately accelerating and decelerating while in reverse. If the clunk or shudder is more pronounced, it confirms a bad inner joint".
91Caprice9c1
05-13-2008, 01:20 PM
Yeah well, this can also indicate a bad motor mount(s), excessive pinion shaft play in the differential, loose suspension components, etc...
What have you discovered thus far?
-MechanicMatt
ahaus
05-13-2008, 04:48 PM
It Is My Experience That You Have It Correct Becauce Wheel On The Inside Of The Axle Turn Has To Make A Smaller Circle Than The One On The Outside. The Joint On That Wheel Has To Flex More. If You Are Talk A Repeated Click/clack While Accellerating.
citydragon
05-15-2008, 10:43 AM
-MechanicMatt
It's a bad left ball joint...will have to replace complete control arm. Thanks!
